Desmo Sedici RR Vs MotoCzysz C1 dal film WALL STREE II
    ? stata mai provata seriamente questa C1?
    General informationModel:MotoCzysz C1 990Year:2008Category:SportRating:74.7 out of 100. Show full rating and compare with other bikesEngine and transmissionDisplacement:990.00 ccm (60.41 cubic inches)Engine type:In-line four, four-strokePower:220.00 HP (160.6 kW)) @ 15000 RPMTorque:108.48 Nm (11.1 kgf-m or 80.0 ft.lbs)Max RPM:16000Bore x stroke:82.0 x 46.9 mm (3.2 x 1.8 inches)Fuel system:InjectionFuel control:OHCIgnition:4 plug mounted coilsGearbox:6-speedTransmission type,
    final drive:ChainClutch:Dry pack with Hydro electro slipper controlExhaust system:FMF Titanium 45mm 4-2-4Chassis, suspension, brakes and wheelsFrame type:Carbon Fiber Frame 5kg with Carbon Fiber Subframe 2.5 kgRake (fork angle):22.5?Front suspension:6X Flex with Ohlins shockRear suspension:DUO spring with regressive damped Ohlins shockPhysical measures and capacitiesDry weight:158.0 kg (348.3 pounds)Power/weight ratio:1.3924 HP/kgSeat height:826 mm (32.5 inches) If adjustable, lowest setting.Wheelbase:1,420 mm (55.9 inches)Fuel capacity:7.57 litres (2.00 gallons)Other specificationsStarter:ElectricComments:Z-Line 4 engine. Twin Crank/ Triple OHC.
    ....che ??
      che sfidona !!!!!!!! li battevo con il mio f10 ..........
        ammazza che paracarri
          che sfida!! ma farsi qualche curvetta seria, no eh..
            asfalto bagnato e qualche ramo sulla strada :gaen::gaen::gaen:
              Bello sto film, quello che porta la D16 c'ha la street
              La C1 se non ricordo male volevano produrla ad un prezzo di oltre 100.000$ (se non erro) ed avere 220hp, ma mi sa che non l'hanno fatta pi?.
                pota a me sembra la EXTREME!!!!
                  La scena del film ? OSCENA... e OFFENSIVA per persone dotate di intelligenza..
