Originally posted by Martino
View Post
1
Inspect packaging and make sure it is not damaged (if applicable):
2
Remove packaging (if applicable);
3
Inspect motorcycle and make sure it is not damaged;
4
Make sure standard kit supplied is complete (use checklist in the kit);
5
Install Plexiglas
6
Install rear-view mirrors
7
On request of the Customer, install passenger seat and footpegs
8
Prepare the battery
9
Check the drive chain tension;
10
Check tyre pressure (Front: 2.1 bar, Rear: 2.2 bar);
11
Check coolant, brake and clutch fluid level (and top up if necessary);
12
Check engine oil level (and top up if necessary);
13
Check lighting, turn indicators, horn and controls. Check headlight beam height. Check handlebar freedom of movement and for any interference;
14
Check key operation and steering lock on the right and left sides;
15
Check front and rear wheel shafts tightening (Front: 63 Nm?5% - Rear: 230 Nm?10%);
16
Check tightening of brake calliper screws (Front: 45 Nm?5% - Rear: 25 Nm?5%);
17
Fill with fuel until the low fuel light goes off (approx. 5 litres);
18
Check the operation of engine stop switch, side stand switch and clutch lever switch;
19
Check the presence of any technical updates and recall campaigns on the DCS;
20
Install any Ducati Performance accessories requested by the Customer and check their operation;
21
Final test and road test of the motorcycle (testing the safety devices, and electric fan);
22
Reading of the error memory with DDS 2.0 and check of Software version update on control units (use the Global Scan function);
23
Clean the motorcycle;
24
Activate the motorcycle warranty and fill out the on-board documentation (general warranty terms and conditions);
25
Explain motorcycle operation to the Customer and deliver all standard documents and literature.
