Le foto parlano da sole...molti particolari FEBUR:
-Engine is an 06 with high comp pistons and a few other mods. The bike is pushing around 165HP.
-OHLINS Black Anodized Front End (custom)
-OHLINS Black Anodized Radial Billet Bottom Kit (custom)
-OHLINS Black Anodized Rear Shock
-OHLINS Rear Spring RED
-OHLINS Damper with Superbike Kit
-Brembo Radial Calipers
-Billit Caliper Spacers
-Ti Caliper Bolts
-Brembo RS Rotors 10mm offset
-Ti Rotor Bolts
-F05 Brak Line Kit
-Brembo Radial Break Master 19x20 w/ Remote Adjust
-Brembo Radial Clutch Master 16x18
-Brembo Factory Remote Adjust
-Brembo Micro Switch (Break Light)
-Brembo Break Res (custom)
-Brembo Clutch Res (custom)
-Goodridge Banjos and Bleeders
-RS Corse Slipper Clutch
-F05 Carbon Clutch Cover
-AFAM 38t Rear Sprocket, 520
-RS Lightened 14t Front Sprocket 520
-DID ERV3, 520 Chain
-Billet Rearsets, Black Anodized, Race Shift Pattern
-F1 Factory Quick Shifter, Carbon Switch Bracket
-Billet Fuel Cap, Quick Release
-Suede Seat
-Black Anodized Triple Clamps
-Black Anodized Subframe
-Factory One Peice Carbon Tail
-All Carbon Body (Febur)
-F05 Billet Rear Caliper Re-Locate Bracket
-57mm into 60mm Termi Full Exhaust w/ Ti Can
-High Comp Billet Pistons, Ti Wrist Pins
-F05 Windscreen
-Billet Crank Case Breather (Red)
-Mag Single Sided Swingarm Powercoated Black (Febur)
-Mag 10-Spoke Marchesini Wheels
-AFAM Quick Change Carrier
-Ti Caliper Bolts
-Ti Rotor Bolts
-F05 Brak Line Kit
-Suede Seat
-F05 Windscreen
