Engine Type Two-stroke, two-cylinder with crankcase reed valve induction
Displacement 781 cc
Bore and Stroke 82.0 x 74.0 mm
Compression Ratio 7.2:1
Cooling system Inducted water
Carburetion Twin BN40 Mikuni
Ignition Digital DC-CDI
Lubrication Pre-Mix
Starting Electric
Propulstion System Jet pump, axial-flow, single stage
Maximum Thrust 699 lb.
Overall Length 90.6 in.
Overall Width 28.7 in.
Overall Height 28.9 in.
Dry Weight 351 lb.
Fuel Capacity 5.0 gal.
Color Jet White/Lime Green, Jet White/Firecracker Red
Warranty 12 months
Good Times? Protection Plan 12, 24, 36 or 48 mo
Per ulteriori info
Displacement 781 cc
Lubrication Pre-Mix
Starting Electric
Dry Weight 351 lb.
Warranty 12 months
Per ulteriori info
