ZX-10 "RR" (in inglese)
    Dal sito motorcycledaily.com
    Kawasaki May Produce ZX-10RR
    UK weekly MCN is reporting that Kawasaki may produce an even more hard-core version of its ZX-10R superbike, said version likely to be called the ZX-10RR.
    According to MCN, the ZX-10RR (if produced) will almost certainly feature close to 200hp (claimed output at the crank, of course) and an adjustable swingarm pivot point, as well as lightweight bodywork and wheels along with other trick bits to reduce weight. Other possibilities (some of which might be a little far-fetched) may include a drive-by-wire throttle setup, traction control, and a big bang firing order for the 1000cc four-cylinder powerplant. The 'RR' might also feature a higher-spec suspension than that offered on the standard ZX-10R.
    Do we really think Kawasaki will produce this bike? Well, the company has created some incredible bikes since it made the commitment a few years ago to make its bikes the fastest, most powerful, and most hardcore in the industry. A ZX-10RR would seem to be just a logical continuation of that theme, and so we'd say it isn't out of the question at all. Keep in mind that Kawasaki builds two versions of its supersport machine, including the 636cc ZX-6R and the race-homologation ZX-6RR. MCN indicated the 10RR would be intended as a homologation special for World Superbike Racing.
    Speriamo su base 04/05 e non 06...............
      '06 sicuramente...
        E' comunque solo una congettura...vedremo...
          Se sarà veramente così...House mi crepa d'infarto!!!
            tanto se la fanno sar? sicuramente in serie limitata e magari fanno come per R1 Sp. Anche se avesse 200 Cv che ce ne facciamo, a me sebrano troppi 160 cv... House stai tranquillo!
              Secondo me la faranno solo se la 06 avrà un buon successo commerciale.............quindi non la faranno!!!
              Dai scherzo!!!
                Immaginate però una versione stradale di questa... Ohlins davanti e dietro, impianto frenante racing, ruote super leggere, carbonio a volontà, motore più cattivo ed una coppia di Akra sputafuoco.
                Me la compro!
                  alla faccia delle fiamme!!!!!
