YAMAHA KIT YEC R1 2004
    IL KIT CONTIENE I SEGUENTI PARTICOLARI:
    Engine parts (All new for 2004)
    Spark plug set
    Cylinder head gasket
    - Thickness = 0.30mm
    Cylinder base gasket
    - Thickness = 0.10mm
    Inlet & Exhaust camshaft
    - Modified duration
    Bellmouth set
    AIS plug set
    - To remove AIS
    Wire harness set
    - For sprint races
    Clutch spring set
    - Increased pressure
    ACM rotor
    - Smaller rotor than standard
    Engine Control Unit (ECU)
    - Revised fuel injection mapping
    2004 YZF-R1 Kit manual and CD-Rom
    - 5 Languages
    - Thickness = 0.35mm
    - Thickness = 0.15mm
    Clutch boss
    Head and tail light harness set
    - For endurance racing
    Sub radiator set
    - Increases cooling capacity
    Drive sprocket
    - For 520 chain
    Drive sprocket nuts
    Maintenance set
    Variation gears - Not available yet
    - Alternative ratios for first, second and third gear
    Pistons
    - To be confirmed
    Intake and exhaust valves
    - To be confirmed
    Engine maintenance kit
    YEC maintenance sets provide the engine tuner with all the gaskets, oil seals and piston rings required to rebuild three engines
    Era gi? stato postato... prezzo kit?
      se tradotto in italiano forse e' meglio
