leggete questo testo tratto dalle istruzioni di installazione
This bike uses a fly-by wire system, so conven-
tional tuning can not be performed for all RPM
and throttle ranges.
The GREY wire from the PCIII is attached to the
throttle blade angle sensor of the throttle bodies
which is NOT directly correlated to the throttle
grip position. Because of this when setting the
throttle position in the PCIII software we recom-
mend on resetting only the closed position after
the bike has completely warmed up. Use the
arrow key (<) next to CLOSED to perform this
step and then click OK. Do not try to set the
OPEN position unless you are on a dyno and
above 9000rpm.
You will notice that in the maps there are not
detailed values below 9000rpm at 100% throttle
and below 7500rpm at 60-80%. This is because
the throttle blades will not open more than 60%
below this RPM range no matter how much throt-
tle input is given. Therefore this area can not be
tuned.
chiedo a chi e' piu esperto di me di interpretarlo...(no di tradurlo,so che c'e' scritto ) ma forse non capisco bene tecnicamente che significa...forse che sotto i 9000 e' completamente inutile?
above 9000rpm.
tuned.
