Dall'inizio di Giugno sono 6 i richiami per la Panigale negli USA. Certo, sintomo di cura del cliente da parte della Ducati, pero'.....
Ducati 1199 Panigale Recalls Now Total Six ? MotorcycleDaily.com – Motorcycle News, Editorials, Product Reviews and Bike Reviews
#1 ? Summary:
DUCATI IS RECALLING CERTAIN MODEL YEAR 2012 PANIGALE MOTORCYCLES BECAUSE OF AN INCORRECT SCREW USED TO RETAIN THE SWINGARM TO THE REAR SUSPENSION LINKAGE.
Consequence:
IF THE LINKAGE DETACHES FROM THE SWINGARM, CATASTROPHIC SUSPENSION COLLAPSE WOULD OCCUR AND ADVERSELY AFFECT THE ABILITY TO SAFELY HANDLE THE MOTORCYCLE, INCREASING THE RISK OF A CRASH.
#2 ? Summary:
Ducati is recalling certain model year 2012-2013 1199 Panigale motorcycles manufactured from March 16, 2012, through July 12, 2012. The exhaust butterfly valve bowden cable cover could melt or burn due to excess heat of the catalytic converter.
Consequence:
Melting and burning of the bowden cable cover could lead to smoke and/or fire.
#3 ? Summary:
Ducati is recalling certain model year 2012-2013 1199 Panigale motorcycles manufactured from March 16, 2012, through July 12, 2012 . Due to an incorrect assembly tolerance, the Uniball bearing on the damper rod eyelet could slip out of its seat on the Ohlins steering damper.
Consequence:
The steering damper can detach from its mounting point which can lead to loss of control of the motorcycle, increasing the risk of a crash.
#4 ? Summary:
Ducati is recalling certain model year 2012-2013 1199 Panigale motorcycles manufactured from March 16, 2012, through July 12, 2012. Screws that secure the steering damper to the steering head could fall out due to an insufficient amount of Loctite applied to the threads.
Consequence:
The steering damper can detach from the steering head which can lead to loss of control of the motorcycle, increasing the risk of a crash.
#5 ? Summary:
Ducati is recalling certain model year 2012-2013 1199 Panigale motorcycles manufactured from March 16, 2012, through July 12, 2012. The right and left swingarm shaft pivots can loosen.
Consequence:
The swingarm shaft pivots can loosen from the swingarm which can lead to loss of control of the motorcycle, increasing the risk of personal injury.
#6 ? Summary:
Ducati is recalling certain model year 2012-2013 1199 Panigale motorcycles manufactured from March 16, 2012, through July 12, 2012. The front brake master cylinder reservoir hose might interfere with the threading end of the reservoir retaining screw.
Consequence:
The front brake master cylinder reservoir hose might interfere with the threading end of the reservoir of the retaining screw causing damage to the hose, which could lead to a front brake system failure, increasing the risk of a crash.
#1 ? Summary:
Consequence:
#2 ? Summary:
Consequence:
#3 ? Summary:
Consequence:
#4 ? Summary:
Consequence:
#5 ? Summary:
Consequence:
#6 ? Summary:
Consequence:
